- Joined
- May 1, 2019
- Messages
- 756
- Points
- 241
punto evo, 1.2, 8 valve 2011, the one with led tail lights, 12v 21w bulb ind and stop lamps.
the centre extra stop light, in the hatch upper area, is that led on bulbs please ?
the drivers side tail light unit, its wires come from the front of the car please ?
we know of the earth point on the left lower corner which has been cleaned over the week end.
we could do with exact wiring info regarding the tail lights led wiring please, where do wires come from and internal wiring of the led's.
the lad says all lights all ok at present this morning, but, the car has been experiencing intermitant loss of tail lights, and malfunction of r/h/s tails lights, which give me the impression of a bad earth.........
we can solder extra earth flying leads, to car body, on the bulb unit tracks, but could do with exact wiring, and exact wiring of led's please.......
been on e learn but no exact punto info.....which is annoying. grande punto info better than nothing I suppose but exact info would be good. Haynes manual is some help but again need exact punto evo info/wiring diagrams......
any common faults about the light units with water ingress ?
we know about the bulb holder unit "seal" and the lamp unit square "seal". The left side lamp unit square seal has an immpression of the ribbed wiring protector, since leaving the factory we recon. slight corrosion seen on body close to the earth point due to a water leak. Not much of a leak, but a dribble of water none the less, causing corrosion.
all help greatly appreciated.
thanks
thanks
