Brooky58
Hi and thanks for the welcome to the forum.
I have a recently bought 2010 mk2 Panda on which the front screen washers do not work. I can make them work just once by blowing back down the screen washer pipe, then refitting it and operating the washers. They then work until I release the switch. Won’t work a second time. There’s only one pump, with a double output valve attached. I can only assume that the pump polarity is changed when swapping between front and rear washers, so the fault must lie within the attached valve. It looks as though I can dismantle the valve, if I’m careful. Is this a common problem on these cars?
