Scott8105
Hi all a newbie to the forum but a long time lurker and you guys have helped me many times with the wealth of information in this forum.
My Fiat days started more years ago than I'd like to admit with a 1.6 131 mirafiori - so that's a clue !
Well I'm back with trying to keep the other halfs mk1 Punto on the road - its become a challenge this year. latest episode saw the head drop the end off a valve (it's a 1.1 8v and the cam belt was intact but it had been using loads of oil) and the valve bounced around in the engine destroying the head and punching a hole in the piston ( pics available if you're interested ). So a quick ring around has found me a 1.2 8v Spi head and block which I have duly installed with the hope for a reasonably straight swap. So two things that have halted my progress: -
1) the down pipe is too short (gutted its a month old).
2) sump is leaking - rusted through and the 1.1 isn't compatible - I think!
So I ask the fiat expert masses, can I buy a 1.2 down pipe and marry to the 1.1 cat ? Is the pipe diameter the same?
And secondly is there anything else I need to change? I think the ECU should be okay reading the other threads. It's all gone in without trauma so far.
Thanks in advance for any help.
Scott
Scott
