Technical MES problem
Baglady1990
One job always leads to another
west yorks
Guys when I’m trying to connect to my engine with mes I’m getting this!? It doesn’t matter what control module I try either I’m using yellow cable with my modified obd2 is that right? What am I missing
This tells you what cables to connect for what procedure:
https://www.multiecuscan.net/SupportedVehiclesList.aspx
Fiat
500
1.2 8V Magneti Marelli IAW 5SF8 CF5/EOBD Injection (8V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Magneti Marelli IAW 5SF8/SDU CF5/EOBD Injection (1.2 8V LPG, 1.4 8V LPG) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Magneti Marelli IAW 5SF9 CF5/EOBD Injection (1.2 8V, 1.4 8V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Magneti Marelli IAW 9GF CF6/EOBD Injection (1.2 8V LPG) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Magneti Marelli IAW 9GF CF6/EOBD Injection (1.2, 1.4) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Marelli SELESPEED CFC328 Automatic Gearbox |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Marelli SELESPEED CFC328 CF6 Automatic Gearbox |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Marelli SELESPEED CFC328F Automatic Gearbox |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Bosch ABS 8 ESP |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Bosch ABS 9 ESP |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Continental Airbag (Ep - PROXI) |INFO|DTC|DTC EX|PRM|ACT| ELM A3
Continental Airbag MY12 |INFO|DTC|DTC EX|PRM| ELM A3
Siemens Airbag MY06 (Ep - PROXI) |INFO|DTC|DTC EX|PRM|ACT| ELM A3
TRW Airbag MY12 |INFO|DTC|DTC EX|PRM| ELM A3
Delphi Electric Steering |INFO|DTC|DTC EX|PRM|ADJ| ELM
Delphi Electric Steering MY12 |INFO|DTC|DTC EX|PRM|ADJ| ELM
Service Interval Reset |INFO|ADJ| ELM A3
Service Interval Reset MY12 |INFO|DTC|PRM|ADJ| ELM A3
Service Interval Reset MY13 |INFO|ADJ| ELM A3
Service Interval Reset TFT |INFO|ADJ| ELM A3
Convergence Lauberhorn (Blue&Me) |INFO|DTC|PRM| ELM A3
Convergence Marelli/Microsoft (Blue&Me) |INFO|DTC| ELM A3
Convergence Marelli/Microsoft C3 (Blue&Me Nav) |INFO|DTC| ELM A3
Instrument Panel Marelli |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM A3
Instrument Panel Marelli MY12 |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM A3
Instrument Panel Marelli MY13 |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM A3
Instrument Panel Marelli TFT |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM A3
Uconnect Radio/Nav 5" |INFO|DTC|PRM|ADJ| ELM A3
Uconnect Radio/Nav 7" |INFO|DTC|PRM|ADJ| ELM A3
Body Computer Delphi (312) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM A3
Body Computer Delphi (312) MY12 |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM A3
CAN Info |INFO| ELM A3
CAN Setup / PROXI Alignment Procedure |INFO|ADJ| ELM A3
CAN Setup / PROXI Alignment Procedure (2014+) |INFO|ADJ| ELM A3
Denso climate control (Single zone) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM A3
Denso climate control (Single zone/PTC) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM A3
Litronic XENON headlamp (left) |INFO|DTC|PRM|ACT|ADJ| KLELM A3 P12
Litronic XENON headlamp (right) |INFO|DTC|PRM|ACT| KLELM A3 P12
Parking control Valeo |INFO|DTC|DTC EX|PRM|ADJ| ELM A3
Tire Pressure Control (TPMS) |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM A3
KL - KKL/VagCom/OBDKey interface
ELM - ELM 327 v1.3+/OBDLink/OBDKey interface
A1 - ADAPTER CABLE 1 (green)
A2 - ADAPTER CABLE 2 (red)
A3 - ADAPTER CABLE 3 (yellow)
A4 - ADAPTER CABLE 4 (purple)
A5 - ADAPTER CABLE 5 (blue)
A6 - ADAPTER CABLE 6 (gray)
3-Pin - 3-PIN ADAPTER CABLE
P1 - Pin 1 (for interfaces with pin switch)
P3 - Pin 3 (for interfaces with pin switch)
P9 - Pin 9 (for interfaces with pin switch)
P12 - Pin 12 (for interfaces with pin switch)
P13 - Pin 13 (for interfaces with pin switch)
looks like you only need the OBD2 cable for the engine.
Did the set.up in F9 correctly ?
Cable showing all correct.
You do have the ignition on.. ??
Yup all seems ok in f9 I’m trying to re write mileage now and all I’m getting is failed to execute... I used it on my last fiat 500 and I managed it .... it did say latency too high in f9 does that mean anything?IMG_2733.JPG
