thats something worth checking yeah. it will also mean differnt settings in 'engine constants' too. I still stand by an IR thermometer as a handy bit of kit when testing engines, checking the exhaust ports should give a good clue as to what cylinder is doing what.
ahh, i see what you are saying re timing and that makes sense now.
when wiring your VR sensor, which way round did you do it? I assume you use twin core sheilded cable, and then sheath is grounded at both ends? from my loom notes for my build;
Code:
07 Shielded (red core) TDC negative signal
24 Shielded (white core) TDC positive signal
