Technical Marea TD100 Problems
DAVIE17D
Hi Just Bought Fiat Td100 Having Problems With It Car Starts And Drives Fine Away You Go Next Thing Starts To Miss Know Power Loads A Smoke Rev It Hard A Couple Of Times It Clears Away You Go Again Same Thing Over And Over Again Been Told It Was The Injectors So Ive Had Them Rec Problem Still There When The Cars Ticking Over Its Fine The Smoke That Comes Out Is Like Unburnt Fuel Loads Of It .help Please Its Doing My Head In .....
most likely culprit is the advance solenoid if smoking is intermittent. Also check the wiring around the injection pump and the engine loom connector down beside the battery for poor connections. If you cant do any of this, take it to a diesel specialist and mention the advance solenoid..
Owen.
