Howdo Folks,
I've owned my TD 125 HLX Marea since 2007 (1998 model), and have been very happy with her. Unfortunately, she's reaching the point where problems that don't fit the "General Maintenance" category are occurring. For example, recently I ended up paying £400 to have the shifter in the gearbox replaced....
My Marea was serviced recently, and here's a list of the non-standard problems that were identified:
1. o/s inner drive shaft boot split.
2. o/s/r radius arm needs replacing.
3. n/s/r radius arm needs replacing.
4. o/s/f bottom ball joint has slight play.
5. n/s/f bottom ball joint has excessive play.
In addition to all this, when the MOT (due in late May) is carried out, I'm probably going to be looking at a complete set of brake disks.
Taken in isolation, not a single one of the above would put me off, if that was the sole problem. However, when combined, I've been informed I'm going to be looking at a major bill - probably in excess of £1000, including parts and labour.
I'm far from being a car expert, but I have enough knowledge to know that 2, 3 and 5 are definite MOT failures in waiting. I suppose I'm posting this to get a second opinion though, and am looking for the opinions of mechanically-minded people who've done a lot of work on Fiats and are far more knowledgeable than me.
If you fit this category, please could you answer the following two questions:
1. On a scale of 1 - 10, "1" being "simple" and "10" being "an expensive nightmare to sort out", what would you give the above jobs? Any detail about the effort required for each one would be great..
2. If you were me, would you send my Marea off to her final resting place in the great scrapyard in the sky?
Any answers and opinions would be massively appreciated, People.
Cheers.
James
Cheers.
James
