Hello!
On my Stilo Abarth i experience heavy kangarooing when in 1st gear pull-off and also a little between gears. I already replaced the complete clutch incl. hydraulic bearing and flywheel. Also the accumulator and clutch solenoid are replaced, but problem still exists. Problem seems worse when it got colder.
I use FiatECUScan to read out my selespeed and engine ECU. But when i monitor the MAF values i see something strange. I attached a screenshot with the values of my MAF.
As you can see the airflow, air temperature and even water temperature drops to 0 frequently. These values are monitored from within the Motronic Engine ECU.
Questions:
- I assume i should see a normal line in the graph without these 0 droppings?
- I could conclude that the MAF is gone, but why is the water temperature also dropping?
Anyone experienced this before?
Questions:
