Mijenjaj ulje........./Change oil........
Repl. date Replacing Replaced Description
21215/20
14.04.2010 55574101 55565321 BEARING 58,97€
14.04.2010 55574104 55181941 BEARING 60,94€
55181940 - BEARING 63,89€
14.04.2010 55574107 55188083 BEARING 61,73€
21220/20
21.04.2010 55572486 55563923 BEARING 68/45€ x2
NTN-SNR reference OE reference Position Situation
EC.42192.Y.S02.H206 FIAT, VAUXHALL : 55188083 CTOEMB AS1
FIAT, VAUXHALL : 55574107
EC 42217 S01 H206 FIAT, VAUXHALL : 55180130 G DIFAV
FIAT, VAUXHALL : 55563923
VAUXHALL : 55572486
EC.42310.S01.H200 FIAT, VAUXHALL : 55574101 CTEMB AP
EC.43082.S01.H206 FIAT, VAUXHALL : 55181941 CTOEMB AP
FIAT, VAUXHALL : 55574104
VAUXHALL : 55585665
Good point.
But car has enough torque to acc in 6th
Yes but 6th gear is 'synthetic' (so I have heard) and accelerating using 6th gear all the time can cause stress and excessive ware on this 'synthetic' gear causing the gear to fail or cause a whine etc. Someone posted about it the other week. Cant remember who it was though.
M32 geraboxes are on for example Alfa Romeo 159 1.9jtd, to they have to be very robust if they can handle those diesel power and even more diesel torque.
The problem is not the gears, its the bearings at the end of the shaft 5th and 6th gear run on, they are simply not up to the job.
The bearings become noisy and if left start to wear to the degree it lets the shaft move about, this chips pieces out of the gears damaging them, ultimately punching a hole in the gearbox casing.
I have seen my box in bits and I can tell you there is nothing synthetic about the gears, its just a poor design.
That's actually pretty good to have in mind and also makes a lot of sense...6th is indeed only for cruising and it doesn't hurt to shift down for acceleration.
From what I know about gearboxes (which is not much), too "economy" driving is bad for gearboxes...
