I have a Fiat Bravo 1.4 T-Jet that consumes a lot of oil. Compression on all four pistons was fine, but I noticed the spark plug on the first piston was wet. Could it be a problem with the piston oil rings or the valve stem seals?
I think the oil rings do not affect compression, or am I wrong?Wowza!!!
If compression is fine means the piston rings are ok, the problem is the valve stem seals.
Nor do they worn out and the other rings stay fit. If compression is fine, the rings are ok. If you want to put new rings on, you can do it, of course. What's the mileage on the car?I think the oil rings do not affect compression, or am I wrong?
The engine has 168,000 km. It runs perfectly and pulls well, operating quietly. However, as I mentioned, it has high oil consumption and blue smoke. I have installed a new turbo and a complete new PCV valve.Nor do they worn out and the other rings stay fit. If compression is fine, the rings are ok. If you want to put new rings on, you can do it, of course. What's the mileage on the car?
Take a look on this topic and do check your oil pressure and check/clean the oil channel inside CH cover. There was overheating in the upper side of your engine that got the valve seals so toasted and something was causing it.
Just on the first cylinder spark plug or is that the only one you've checked?!
Probably all the spark plugs look the same and the cause is valve seals, as I've told you in the new topic you've opened.
Only the spark plug of the first cylinder is like this, the others are clean
And the compression on cylinder 1 is ok?
I think we should talk about this in your othe topic, to be al in one place. I'll copy these las messages there, too. Reply there, please.
