Hi everyone.
I purchased a Fiat bravo 1.4 tjet 120hp back in May in Italy as a second car. It was in rough conditions, 158000km, original timing belt, thermostat open, shock absorbers original and completely blown, springs not broken but they were sitting 2cm lower than they should because the car was driven without shock absorbers for like 8 years.
Anyways, I started rebuilding it by opening the top head of the engine, changing the rocker cover seal, cleaning all the dirt due to missed oil changes or bad quality oil, inspected tappets, camshafts etc and put everything back.
Did suspension, brakes, rear bushings, basically everything on this car was done since I got it for a good price and I want a car that I can go around Europe with (like my other car) without the fear of breaking in the middle of the road.
The problem that remains and I can't seem to diagnose, is that in every gear, when you just coast, go downhill or simply use engine brake, and then you press the accelerator, there is like a backlash/knock/judder for 1 second and you can hear a knock coming from the engine bay. It's consistant, in every gear, at any speed, and it becomes less apparent with higher rpm, it's louder with lower rpm. You don't need to shock the accelerator pedal to have this, even if you press it gently it does the same.
I read on Italian forums that other people might have had this problem and it's due to the gearbox just being clunky by design, and back in the day they had it changed under warranty but the new one was the same.
Does your fiat bravo's do the same ? Even on diesel maybe ? Also, sometimes when I insert a gear, when I first release the pedal, there is a slight noise, nothing bad, it's just a noise like the gear wasn't fully engaged and it's engagign when lifting the clutch, no grinding, no bad noise, just weird compared to other cars i've driven.
I did inspect everything and including the following:
Re-did driveshaft boots, both inside and outside, checked for play and scorring on the bell of the inside tripod, there are some shiny parts but nothing you can feel by hand. If I hold steady the housing and try to make the inside tripod play, there is some slight play, but nothing bad. I did also a test where I did this at different depths inside the tripod housing, inserting the bearings deeper or less deep, and the play is exactly the same. This was in my opinion not the cause of the problem ,since when the car drives straight, the bearings always go in the same position on the housing, so if that would be the problem, when I insert the tripod bearings completely inside the case, that would make them run in a new position where it usually doesn't run, so the play should have became smaller/bigger, but it did not. The bearings themselves did not have any play in my opinion.
I changed all engine and gearbox mounts of course.
I changed the suspension arms obviously, that would be the first thing I would check too.
I did take off the gearbox and I did the rear main oil seal, flywheel and new clutch. I inspected the play in the primary shaft on my gearbox and there was no play. I also changed all oil seals, but that's irrelevant. I did notice that turning the primary gearbox shaft, there is a lot of free play (when you turn it not when you pull side to side) so I studied the gearbox, and I noticed that when the synchronizers engage, there might be around 2-3mm of free play in those tooth, and that could cause all this "delay/free play", and that would be normal and by design, not a defect, just a clunky gearbox.
The gearbox does not have any symptoms of bad bearings, no whine, no play, shifter does not move when accelerating, when I got the car I pulled out 2.3l of oil from the gearbox which means there was a total of 2.5 (200gr stays inside differential housing), that is more than what fiat recommends and that's how this gearbox should be filled in order to lubricate better the bearing near the 6th gear. I think the fact that it had more oil helped and that's why this gearbox is still ok at this mileage given all the problems that is causing on other cars since it was engineered. I put myself 2.7 oil to carry out this legacy of overfilling and hopefully helping the life of the bearings.
Symptoms did not change since after new flywheel and everything else I did (it obviously was way worse before I did the suspension parts).
I will try to find the videos and pictures and attach them, but if any of you have this "problem" you will definitely notice it because it's very annoying. You just relax and drive slowly, release the accelerator and then when you press it again the car shakes a bit and there is a clunk, it's like the flywheel would be bad, and there are no springs on the clutch disk. But the flywheel is ok, and also even if it would be bad, the symptoms between 2 different flywheels would at least change a bit.
I will try to attach the video of the gearbox "free play" to make you understand what I mean, basically when you move the primary shaft, there is a free play and delay until the differential starts moving, and if you do back-forth, you can hear kind of a "clunk" which is normal but annoying.
Here are some videos and images.
This was the old flywheel, free play is irrelevant and axial play was 1.6mm whilist the new one had 3.3mm of freeplay (barely 1 tooth) and 0.7mm axial play which is well whithing Luk's spec of 7 tooth free play and 3.5mm of axial play if I remember right.
This instead is the driveshaft on the tripod part.
The play is minimal and with the grease that play is almost entirely eliminated. The bearings do not present any axial play.
This is the video with the gearbox play I was talking about. It kind of sounds similar to the noise I get when driving, but wouldn't this mean all c544 m32 gearboxes have this ? That's why I'm asking if you ever experienced this.
I'm also attaching some pictures.
- Model
- Fiat Bravo 1.4 Tjet 120hp Emotion
- Year
- 2009
- Mileage
- 162000
