Must be about a year ago when the Low Brake Fluid light stopped on.
Checked Manual and Goggled problem.
Seems it could be the Handbrake Switch faulty.
I messed about by unplugging wires and made sure they were tight fitting etc.
Then gave up and left till the Light stay on until the MOT came up.
Mechanic called me over to the car. He told me Warning Light was light staying on.
I told him I had tried to fix it.
Mechanic then unscrewed the Master Brake Cap. Put his finger inside. Pulled out the Filter, which I never knew about.
The Brake Fluid was definitely low. Topped it up. Cleaned Filter and put it back in place.
Since then the Warning Light only comes on when I apply the Handbrake.
So simple a fix that I never knew about.
Hope this is of use to others.
