Technical Linkage Bushes
itsamugsgame
Hi. I have a 2010 Fiat Panda 1.1 eco. The rubber Bush on the bottom gear linkage has split and the linkage has come adrift. Does anyone know where I can buy a replacement?
I am struggling to visualise what you want
Gear selection is by a steel ball and nylon socket on both ends of a cable
I am obviously missing something
You can get repair kits
But I would just swap out the cables
I bought them used for around £10
Be aware post 2012 are not a straight swap
I might (begrudgingly) buy a new set. Just over £70 on Autodoc. Buying used I might be in the same situation in a few months.
Or how about. Buy a new set but only change the ball joints from the end. No need to fully replace the whole cable then.
Just a thought
The ones in the photo’s
Are not the same as the three 3 pandas I have owned
In fact all 3 cars have been different cables.
One of those ends is hydraulically crimped on. Isn’t it ?
I think that I'm going to have to remove mine to get the part number from it. I've had problems with this car before getting parts because its apparently on the cusp..
The cable end fittings are crimped onto the steel wire inner. Even if you have access to the tools, the chances of being able to buy just the ends is zero.
When part numbers are uncertain, order both and return one of them. Obviously confirm with the supplier that they are happy to take back the unsuitable items without charging restocking costs.
