Technical  limp mode error code P010F
na1pir
My bravo2 2008 1.6 120hp is regularly put into a limp (safe) mode when a car is driven downhill without any throttle input. Turning it off and on again gets it running at full power again. It happened a few times that I also got a check engine light that later disappeared. I bought a cheap odb key and read out the error code it was P010F on Control unit 10. 70% of my driving is on motorways.
Thanks for any suggestions.
I have a 2010 Dovlo Maxi 1.6 van that throws this code up and goes into limp mode, it seems to happen once warmed up and accelerating on dual carriageway, it has had MAF and MAP sensors plus a lot of time on it , so far with no success. So I will be interested if a solution is found.
