Technical Leaking Diesel Pump
prolecky
Hi all, hopefully someone can help with some info.
I have a 2004 1.9 Diesel Turbo JTD which has developed a leak from the main diesel pump in the engine bay. I have uploaded some photos and the leak seems to be coming from under the rectangular box on top of the pump which is held on by what looks like 4 rather large, 5/6mm, torx head bolts. I have rang Fiats and they do not list an O ring or gasket for this part as it comes comlete with a new pump attatched. It looks like it will unbolt which is why I thought you may be able to replace an O ring or gasket. Any ideas or help with this is much appreciated as need to get it fixed asap.
Thanks.
Search eBay for cp1 seal you'll get full kits for about £20. You'll need to clean that meticulously before you remove the third piston solenoid any crud getting in there could be a very expensive bill for pump and injectors.
Many thanks for your reply ecunotemu. Will order one of those up and give it a go. There had to be a seal in there. Fingers crossed. Thank you.
My jtd 05 2.0 has also developed a leak and have ordered a new pump.
