Technical LCD Display panel required -Linea T-Jet FL2014 India
Navin Talati
Dear friends,
My car is Fiat Linea T-Jet Emotion (Model:FL-2014 India).
During this monsoon, the lcd display panel at the center on the dash stop showing data of Km, date, speed, time, etc. all of a sudden during one ongoing trip. It just glows the hazy yellow light while opening the door and engine ON condition. All other meters of speed, fuel, heat/temp, odor, etc works properly and ok. Only the central Digital Display is not working.
1. Is this central Digital Display LCD panel available? Please show me the source of it.
2. How to replace it by DIY?
Regards to all.
Navin Talati /12-12-2020
Please ask Fiat for advice on this matter as the dashboard LCD should not fail within a car that's only 6 years old. They may still fix it for you at no expense.
It needs a new instrument cluster programmed with Fiat tools or there may be car electricians who fix ECUS and similar parts, they may be able to change the LCD.
Certainly humidity might cause this. Have you tried drying the car with an external electric heater blower inside the car for several hours.
I am facing problem in fiat palio 1.3 mjd diesel.its gear get stuck when engine is on while in engine off it perfectly works..I need to put the gear with engine off then drive car in that gear as gear won't move..next day gear perfectly works..I have seen you faced the same problem for 1.2 fiat petrol model..how did you resolved it..can you call my number
Dear Sir,
I replaced the gear shifter block (which is a white coloured fiber material block) located at the base of gear shifter rod under leather cover(sheath). If you have read my post, I have given all photos for that too.
Gear disturbance (similar type) may also be caused if clutch bearing is damaged (most of the times it may give metallic churning sound). This may also happen if there is an air entrapped in the clutch-fluied column leading to SCC (Secondary/Slave Clutch Cylinder) located on the gearbox body(in Palio 1.2 nv). If the SCC is damaged, then also such problem may happen. Please check all these and give feedback. Please take this thread on an appropriate classified subject title in the forum.
Regards & Thanks.
Navin Talati
Friends,
Please note the #3 & #4 are of different topics. Concerned are requested to shift these TWO posts to the related subject/topic section.
I am updating the matter related to "LCD Display panel required -Linea T-Jet FL2014 India". I opened the meter console and have taken pics of that. Actually what I need is the LCD Panel which is located in-between Speedometer and Odometer.
I don't think individual parts of the instrument cluster are available from Fiat, only the complete module. For example: https://www.fiatdalys.lt/en/catalog/parts/555/10/0/1/3S/0/0/CC1.4/CMBBZ/GDX/operation-indicators-
Additionally, I think the instrument cluster must be programmed to the ECU (for correct milage display, etc) so replacing the whole unit is not a straightforward replacement. If you can't find the LCD module on its own, you could buy a whole instrument cluster from a scrap car and take its LCD out and put it in your own. That way, you shouldn't need to do any programming. If you did need to do the programming, you could look to see if MultiECUScan supports that function.
So you didn't ask Fiat for advice? It is an unusual failure and I believe many car manufacturers might compensate on the cost. This time as you have already opened the whole thing, its warranty is void.
Can someone help to procure the LCD Display screen (with the same specification) from anywhere?
Friends,
Have you managed to resolve this issue. If not I will guide you accordingly.
Dear J4MT,
I am still unable to manage for the LCD display screen for my Fiat Linea (2014 India model). I also contacted the Kava Automobile as per your previous post but they have shown their inability for the same.
Sir, where are you from? and what is your name etc.? Which Fiat & other cars you are holding as of now?
I am interested in LCD display screen for my Fiat Linea.
I have given all the pictures and specifications for the same in my earlier posts in this thread. You may refer as your ready reference.
Regards.
Dear J4MT,
Regards.
Where do you reside? Please send Kava pictures of your LCD rectangular display. Also mention the maker, model and year. I know of Kava in south Mumbai who at that time had the same in stock and he had quite a few pieces. he does test the display before he sells it to you. Another place you can check out is Chore Bazaar, as I procrure some of my accessories from the bazaar. This is near Do Taki. I know the shop that sells accessories for FIAT.
Dear J4MT
I am from Surat.
I contacted Kava... they denied ...as they don't have it.
May I know your introduction sir?
Regards.
