Hi All, advise please, my lambda is south. Problem is that the thing seems to be seized in. Best way to get it out:worship:
Weeks later and the Stilo with Fiat for over 5 days, the light is still on.
Can somebody please advise on it: The Lambda sensor was replaced (because the clever computer said so) by Fiat, the light came back on, then they reset the total engine management program, the light came back, then they ran a complete diagnostic program on the total car (???) and according to the results, the timing belt was out by one tooth (??), that rectified, the light came back like a nightmare.
Now I drive a car that is so down on power that I have to gear down just to get to the top of a hill. Sucking fuel at a rate that will bankrupt me soon, and none the wiser on how to fix the problem.
Please help!!
I have the same problem. I reset the lambda error and 2 month later it show again. Do I need to change lambda och is it other problem? I will check the voltage om lambda first. Brown and black cable.
Regards C
