Greets,
Short story long: When I press the clutch all the way to the floor, something (throwout bearing?) squeaks, and plot twist, the clutch starts re-engaging. Very lightly, It's hard to get the gears in while stationary and impossible to get reverse in without cringing. This started yesterday after ~500 km highway and some high RPM racing up some mountain roads.
Plot twist number 2: I replaced the clutch and throwout bearing 5 months (6000 km) ago. I replaced it due to a squeaking throwout bearing. My 2004 Sporting 1.4 95hp only had 55k at the time. 17 years old, so I figured the bearing died of age. The parts I used
So yeah, I'm guessing that the throwout bearing is being pushed too far and too hard. That's what killed the first bearing and perhaps the second one. I say perhaps as there is no noise partially engaged only when flooring it. The old bearing screamed partially engaged. Is this a known problem? I checked the forums and people complained about broken diaphragm springs and worn clutches, but no constant replacement if the throwout bearing.
I glued a strip of rubber matt (15mm) under the pedal to stop the pedal from going all the way, but i'm planning to drive 5k in April and i'd like to get my car home under its own power, and keep the car of course.
This morning I stopped by the local FIAT and he said he doesn't know of this problem. He obviously recommended to change the clutch again with OEM parts and check the whole actuation system, 800 euros. Either I destroy my wallet or my back again.
Any insight would be great.
