hi all,car is still juddering only on start up,cleaned throttle body,changed leads and plugs and coils,after 5 to 10 sec runs fine,checked all fuses,now thinking if it may be the low tension switches which feeds the coils,can anyone help,yhanks paul
Not sure what you mean by "low tension switches". 12V supply is via the ignition switch and ground is via the ECU. Maybe you need to get a code reader on it if it's a MK2 (see Guides section for cheap [£10] ecu reader if you have a laptop). Sensors for things like water temp, air temp, air pressure and crank position can all give strange symptoms at times.
