Morten, that's an interesting idea but don't forget it's toe that would need to be out as that's the only way to generate severe tyre wear (by just looking at worn Stilo tyres it's clear they've been dragged sideways along the road surface and is not the general wear you'd get from excessive camber).Lets say you drive pretty fast (not important) doing a left curve. A large hole in the road appears, and you have no time or place to avoid it. Left wheel drops into the hole and the suspension does its job - propably. Most of the forces are on the right front wheel, but the anti roll bar will force the left front wheel down to keep traction. Wheen the suspension drops it might loosen the 5 mm play (it has about 5 mm clearance, try opening the bonnet when the car is parked) and twist some degrees before it settles again when it hits the asphalt. So when you are back on track on the straight road, the "camber" adjustment of the top mount has moved. And it might do it again over and over again. This is just a theory... Feedback anyone?
My own view is that tracking dynamically changes as the Stilo enters a curve with a similar effect on the rear (especially if under power). Measuring such a change is a hopeless task and would be pointless anyway since cars generally drive straight most of the time. This really brings us back to the discussion of - "is this a technical design feature or is it a defect?"
There's little doubt in my mind that Stilos do generate tenacious grip on fast curves but I suspect this makes the initial (straight line) tracking all the more critical :chin:
