multihull
Have read the posts on power loss /maf/egr/vgt problems.
I lost power suddenly after stopping foe a short while on holiday in France, engine light came on. In the lorry lane going up hill.
Noticed a flattened vacuum tube on the VGT going to the manifold. Called in at Fiat, at Montlucon, very helpful. Replaced vacuum tube, checked it on tester and said "that didn't fix it you have several error codes, drive carefully if going back to the UK tomorrow". Did so, got home, read posts and started checking.
The car will rev to 3000-3200 revs and stay there no matter how hard the pedal pushed. It is the same when not in gear and on the road in the first 4 gears, 5th stops at 2200 - not enough power.
Have removed the MAF sensor wiring - no change.
Tried connecting the vacuum pipes direct cutting out the VGT - no change.
Removed the EGR expansion pipe and cleaned the muck out, not very much, but very oily. Did not look for the EGR valve as I had not read that far.
My question is If the egr valve is stuck open will it limit the revs to the 3000 rpm mark. If so then I will take it off completely and check/clean.
If my symptom does not match EGR fault is ut a turbo failure.
Your experienced replies appreciated.
multihull
multihull
