There's a guide mentioned in post #1so when you say try and clean it with contact cleaner, what cleaner are you referring to? i want to get some but want to make sure its the right stuff.
Electrical contact cleaner should do it from say Halfords
NumanR, any chance of indicating which Examiner Graph Reading was used as I intend to get mine checked soon (due to the fact my JTD is not compatible with an ELM interface )Ok I decided to check my airflow meter today, it passed the readings on examiner, I then fitted a replacement sensor and retested it. It passed again. However, the interesting thing was that the old unit reacted slower to airflow change, not measurable on a multimeter but when displayed as a graph on examiner recorder it was quite obvious. The drive home was very smooth and appears to have cured the fault. I will monitor the engine performance over the next few weeks but when you check your airflow meter a good unit will not only be correctly calibrated and reading accurately but will also react to airflow change quickly, and this change may not be obvious using a multimeter.
