I've been having some odd power losses and 'flutters' from my JTD of late. Initially I put it down to the cold conditions but as the timing belt was close to being due for replacement I decided to put my car into FIAT for the belt change and service (ouch ) which I hoped might sort it out. I mentioned to the service manager that I was experiencing an occasional flat spot or 'flutter' from the car. However when I got it back the diagnostics checks showed naff all wrong with the car and apparently it didn't show up on a road test either But trust me the problem remains, it's intermittent but there enough of the time to irrititate the hell out of me
Now I've been flicking through this and other forums and I'm now convinced that the symptoms my car is showing are indicative of the MAF sensor failing.
I've read with interest the piece in the punto section about replacing/cleaning the MAF https://www.fiatforum.com/punto-guides/129316-1-9-jtd-maf-sensor-cleaning-replacement.html
Very useful wee guide that
Sadly I've not the facilities or all the tools required to do this in the dry at home so it's going to have to go into my local garage for a 'MAF clean' but I suspect I will have to replace it
Have any other Stilo JTD owners changed their MAF sensor? If so where'd you get it and how much did it cost? I've been looking around (as you do) but nothing beats 1st hand experience
I need the car to be spot on for it's long run down to Watford in a fortnight and a bits time
