Well it had to happen didn't
In nearly 3 years all I've had wrong with my Stilo has been split overboost tubing and a single brake light bulb :spin:
Now I seem to have a real fault and I have to admit it's got me foxed :chin:
Basically, all that wonderful torque JTDs are renowned for is completely missing on mine until I'm well past 2.5k
Hit 3k and it pretty much takes off like a goddamn rocket. The car's no fun to drive though. Change a bit too early (before the red-line) and you fall back into turbo lag land
In other words you either feel like you're driving like a snail or like a bat out of hell :devil: By extreme lag I mean if you floor it at 60mph in top then any passengers in the car will mostly likely think you've just engaged cruise control
Whatever the cause, it's been gradual and certainly not sudden. I first noticed it when the engine didn't quite offer the surge I was expecting but since it still flies if you drop a gear then initially at least I've tended to put it down to driver error.
I've changed the overboost valve and blocked off the EGR so both of those can be discounted.
No engine faults at all but I'll check for stored codes tomorrow. I'm also going to disconnect the MAF and if that fails carry out an ECU reset.
It feels to me like the vanes in the VGT are maybe caked in soot and stuck half open but I'm hoping not as that sounds expensive :bang:
