Panda (Mk3)  issues with driver window...
Orenishii
Hi all,
Thanks to all here I was able to sort my lights issue and my door handles. My driver side window has now decided it doesn't want to open...I had this issue last year, I changed the motor and it was working fine until yesterday when I went to open it and it just doesn't work! It has done this a couple of times since but started working again by itself! Is there something I should be looking at? All my issues seem to be on the drivers side: windows, issues with the indicators/lights, bulbs going front and back....and the boot opening by itself.
Is it time to just send it to an auto electrician? Or is there something I can look at?
All help/advice very much appreciated as it's due for nct (mot) soon.
Can you hear a relay click when you use the switch?
If no, probably door wiring, cut and splice as required.
If yes, possibly the motor. Or door wiring. Or switch.
Have had all 3 over the years. None are too expensive or difficult to fix.
PS. Motor can be changed in 15 minutes without removing the whole mechanism with a bit of fiddling.
Hi all,
I can hear a click in the fuse area when I push the button up and down. I'll have a look at the door loom and see if there's anything amiss there.
I changed the motor last year...
