General Is it my gear box or cluch going
creative335
Hi guys today I been on motorway suddenly when I was on 5th gear around 80 miles my car didnt pick the sppedup rather my revs keep on going up lik an automatic car same happend at 4th gear rest of the gears are fine in first gear i can hear strange noise some times my clutch cable started making creaking noise but can go away with wd40 its 54reg 1.2 8 value punto only did 58k rest it runs very smooth any suggestions ...... Check the attached video and see ur self thts revs going up but not speed ..... Just uploading on youtube as it wont let me upload......
Wow thanks so its not gear box........sorry guys m very new to cars n really scared I really love puntos so whts the advice any bdy live arnd manchester area ... Bury, bolton, rochdale oldham who can sort this for me as I dnt trust ppl here they really rip off already had bad experience....
Let me do it from my laptop not letting me with my mobile thanks......
Could be clutch slipping, check to see there is no oil leaking under the car, there could be a possibility that the oil seal is damaged causing oil to leak out, if there's no oil around it sounds like you'd need a new clutch!
thanks u guys are awsome there is no oil leaks i have checked all around and clutch seems to make dodgy noise to yes most probably i need a new one the issue is i live in bury and i need a decent guy who can repair my car properly even tho its clutch but i need some one who knw fiats.... so if u guys can recomend some one who can sort it out not just rip off thanks..... by the way check this time if my this link is working fingure cross
or check this as well
The small independents survive on reputation so more likely to do a good job. They are also better on labour rates. Which is good because Punto clutches usually don't slip before the pressure plate fails.
You must get the gearbox input shaft seal examined whiles its off the car. There's a very good chance its leaking and the bearings behind have failed. It will need new bearings and seal.
Mr Wild posted a useful guide on gearbox bearings.
Got quotations labour going to cost around 80 and the clutch kit costs 69 with two year gurantee the make is some thing like valeo..... Starting with v what do you think guys should I go for it ...
£80 is a very good price. I would be happy paying £120 plus parts for clutch swap.
You need to factor in the gearbox job. Its not much in parts (any bearings factors will stock them) but it will take some labour time.
Try get some reference on the guy's work, but in the end he has a reputation to maintain.
He is been doing it for long time kind of engine replacement expert asian lad but I heard he does solid work n can take tenner off if u ask him to reduce price n ill print out some stuff from forum and gave it to him just for reference ......
guess what guys been driving car all day and clutch is not slipping nw wht u guys recommend should i still replace my clutch or keep on driving the car till the time its fully nakerd lol or dont take the risk and get it changed thanks will post him on recommendation...
If clutch action is smooth it may be ok. If its lumpy or springy the pressure plate is failing.
Put it it 4th gear and try to drive away. If it doesn't stall clutch is slipping.
If all seems ok, use the car until symptoms get worse. Keep gearbox oil topped up.
