superbaker121
Have a 2009 Fiat Panda 1.1. Has over the months developed an intermittent cut out. Starts fine and runs fine but the engine will cut out and restart if you are moving like bump starting or if you pull up it starts on the key. It got to the point where when it cut out the engine light came on and it took a while to start.Was taken to Halfords garage to be diagnosed.They said it neede a new crankshaft sensor which they would fit for £193!!!!. Got one from a parts supplier on Ebay for £20 as it was in an easy location to fit. Fitted new one and problem persisted which seems it was something else possibly wiring fault. Took it to another garage to be diagnosed and they diagnosed crankshaft sensor problem with code P0335. They suggested taking it to a different garage to be diagnosed who maybe are better at the fault finding. I do have a mate who is skilled in this dept who says that its probably a wiring problem and needs to know where the ECU is located. Is it behind the dashboard as i do not have a manual for this vehicle.
