- Joined
- Jul 31, 2017
- Messages
- 53
- Points
- 14
Hi all
my 2000 punto mk2 188 5 door has a problem which showed up for the first time today. After driving the car and jumping out, only the door into which the key was inserted and turned locked. The other doors remained unlocked. This was tried on both front driver’s and passenger’s side, and only the door I was locking actually responded.
Then after driving a short distance it was all back to working normally, and the key locked and unlocked all four doors, so it’s something intermittent.
Does anyone know what can cause this? Today is the first cold weather (0C) so maybe there’s some thermal element to this problem - a loose connection showing up just because a wiring loom connector shrank a tiny bit, perhaps? Logically, if it’s affecting all four doors it should be at some central control until under the hood / bonnet, rather than within the doors themselves - anyone know where this unit might be? Then I could try just unplugging and replugging the wiring loom connector, maybe with a squirt of contact cleaner for good measure?
