trekkingnut
- Joined
- Apr 13, 2019
- Messages
- 90
- Points
- 86
Another issue with the Doblo camper after battery went flat. I noticed backlight flickering which was odd as ignition/lighting was off. Tried to start and was dead so disconnected battery earth and connected CTEK charger. After 3 hours charger had got very hot and charge bar was still on same level so I disconnected it and turned ignition on but no display (odometer) and only engine light, brake and airbag lights came on. I turned on radio and that was fine then the external lights and they came on but no backlighting on instrument cluster either so think something inside it has died perhaps? - checked all fuses relating to cluster including the big ones in engine bay and all are ok.
Sounds like an expensive fix but hoping someone has had similar issue to me and sorted theirs out - I will put a new battery in tomorrow but doubt the panel will work as radio was ok with old battery but will try and start it up. such a pain as MOT due soon too!
