General  Inlet manifold check
koalar
Distinguished member
Cheshire
Can someone on check if the spigot where the small breather hose is just a spigot with a hole or if there's a valve screen or filter fitted
Is it likely to get block, jammed
@irc any in your spares to inspect
I suspect it's just a hole, but if there's anything that could gum up might need cleaning while sorting out oil fouling MAP sensor
The only one I've got handy where i am at the moment is from a Dualogic, so slightly different, but...
I can get a small spiral brush in about 58mm before it stops, but that could well be an internal bend. However, short of breaking it open i can't really be sure. Air flows fairly freely when blown through a pipe.
I can have a look at the one from a 1.1 next time I'm near it if you need more.
