Inertia Switch
Inertia Switch
Dave
Can anyone tell me where the inertia switch is located on the Fiat Brava ( Y Reg ). Ran over someones tail pipe and car won't start now. Think the fuel cut off has taken effect but don't know how to reset.
passenger side footwell left hand side under the ecu.
if you follow the plastic trim on the door sill forward you will see a round opening its in there
Pete
Pete
Switch Not Working
Tried that switch to no avail, does anyone know a way to bypass / reset the switch.
Re: Switch Not Working
to reset the inertia switch press down on the rubber top
pete
Pete
Switch Not working
The inertia switch doesn't seem to be working, pressing it has no effect, can it be bypassed...
Re: Switch Not working
are you sure its the inertia switch?
Pete
sorry, as in is the inertia switch the problem?
it can be by-passed, but its not advisable, by just taking it off and connect the wires together to make a switch.
Pete
Then its not the cutoff switch causing the problem.
some bravo have them under the passenger seat? have you tryed there?
Paul R
If that button has not popped up then it won't be the problem, What is wrong with the car?
Does it turn over ok when it starts up?
Have you checked that the bump has not disconnected your battery leads? HT leads? or anything else under the bonnet?
:) Bravo my son Bravo!! :)
Switch Not the Problem
Checked out the car again and the inertia switch wasn't the problem. The problem was running over the exhaust cracked the crank shaft sensor so the engine wouldn't fire, same symptoms as if inertia switch triggered.
Re: Switch Not the Problem
ahh! i`ll have to remember that one
is it all sorted now?
Pete
Sig courtesy OF Roberto! (Cheers Man)
K
5
571
colin
C
L
2
348
L
R
5
460
A
B
5
766
Anonymous
A
S
4
698
Anonymous
A
