Why not just leave the current set-up it works fine and has a replaceable filter
Most of those aftermarket foam things provide less filteration and may even reduce performance by sucking in more warm air
I've looked a little bit online and can't seem to find one that is made for your car.
I can suggest you use intercooler piping and silicon hoses to create. Custom one. That's what I've done with my car and it seems to work well and looks good too!
Josh
Hi guys went ahead and actually bought a universal one kept the airbox on removed the filter inside and attached the new filter to where the normal intake pipe would be. Believe it or not it actually has a noticable effect on the response of the throttle and doesn't suffer from any heat soak or the lot. All in all so far so good.
