Indicators and Door Sensors
daKid
I'm trying to hook up some wires from my alarm and need to find the indicator flasher wires, open doors and open boot wires in or near the drivers side fuse box. Can anybody help? Thanks in advance, daKid
i can't help mate but if i was you i'd go and buy a haynes manual, it will tell you where all of the wires are in there!
Right, update. I've found the indicator wires, they are in the fuse panel and are light blue x 4, left, right, front, back. After 2 hours of poking wires with a multimeter I got there. The next problem is with my boot light. I was going to run a line from my boot light but discovered that the light doesn't work. The bulb is fine but there appears to be a voltage running from the light loom all the time. Any ideas?
Re: Thanks
Yes, there will be 12v at the boot light at all times.
Your boot light swtich needs a clean.
