lee89
Bit lost on this one really, spent all weekend trying to figure out why it wont idle properly. When cold it revs up and idles at 3500rpm when warm it idles keeps reving itself between 1000-2000 rpm. It squirts fuel in at 1000 then stops, revs itself as its leaning out then squirts more fuel in at 2000 so the revs drop back to 1000 then the cycle continues.
Its had a new coolant temp switch a few months back and this weekend a new idle control valve, throttle potentiometer, air temp sensor, map sensor, lambda sensor, crank sensor. I even got a complete throttle body from scrap yard just as a test and still no change.
There are no air leaks, vacuum gauge reads normal and still goes ok.
Ive tried disconnecting the battery and leaving it off over night, ive tried the supposed ecu reset procedure in haynes manual and still nothing, ive checked all the sensors and im running out of ideas now.
The only way it seems to sort of idle normally is when the map sensor is unpluged and the injector light comes on and goes into default mode.
Any one got any ideas?
