I would just try a different spanner. If you have a 12-sided ring spanner, that ought to give you another half-a-flat you might be able to use, to get the ring onto the nut and still have a few millimeters to turn it a few degrees.
Don't cut the nut off, since if you can't find a way to unscrew it, you won't find a way to screw on its replacement. You need to find a way to access it.
The manifolds are usually attached to the engine before the engine is hoisted into the car from below. Last/only time I had this similar problem, I managed to get a spanner onto the nut from underneath.. but it was a lot of effort, completely out of proportion to the job I was trying to do..
It'll help if you can find someone to hold the spanner onto the nut while you only have to concentrate on trying to unscrew it. If the head comes off the nut, you'll be ducking under the car and out again half a dozen times or more to re-hook it.
Ralf S.
Ralf S.
