I was thinking about how well the air conditioning can get the cabin of the Panda chilled on a hot 30˚ day like today as I drove home for 45 mins in my older model without air con.. decided it's now a must for the next Panda
Is it sore on the fuel consumption for the 1.2?
Assuming it's in proper working order, the A/C in the 1.2 is perfectly capable of cooling the car on a 30˚ day (remember this wouldn't be considered hot for a summer day in Southern Europe).
The radiator fins on the A/C condenser do tend to corrode away quite quickly in the UK climate (you'll see this quite clearly if you look behind the grille on a car that's more than a couple of years old), but this doesn't seem to have a great deal of effect on its performance.
A/C uses quite a bit of power, and the impact on economy is greater than most folks realise - though that shouldn't put you off using it. The exact percentage will depend a lot on the outside temperature, the kind of journey you're doing, and the way you drive. Expect a drop of somewhere between 5% and 20% when it's in use - the percentage effect is significantly greater if you're an ecodriver. Some folks will claim it's marginal, but this is wishful thinking and really just shows how hard it is to measure a 10% change in short term fuel economy, combined with an understandable reluctance to drive on a hot day with the windows shut for the 100 miles or so it takes to get a reasonably accurate consumption reading.
The generally accepted wisdom is that, in fuel cost terms, it's more efficient to open the windows below 50mph, and turn on the A/C above that.
In cruise at a steady 50mph on the motorway on a 30˚ day with the windows shut, you'll lose about 10mpg. At 70mph, you'll probably lose only half that. Open the windows, and you'll lose some or all of what you'd otherwise save.
In short, use it when you need to, and turn it off when you don't (but run it for at least a half hour once a week to keep the system in good order). Running it continuously is the equivalent of keeping the central heating on and opening the window if you feel a bit too warm. Turn it on in mild (8-15C) but damp weather, as it's an extremely efficient dehumidifier (mine sees more use in winter than summer).
Also, despite what some folks think, in the UK it's not a 'must-have'; the vast majority of motorists managed just fine without it for most of the first 100 years of motoring. Until about 1980, it wasn't even an option on any but the most top of the range vehicles.
Also keep an eye on the temperature gauge if you're using it on a hot day in slow moving traffic; if the coolant temperature rises above normal, turn it off (and if it doesn't go down, turn the heater up to maximum). If the cooling system is in good order, this is unlikely, though you'll probably notice the radiator fan cutting in and possibly switching into fast mode. Turning the A/C on when stationary with the interior fan on its highest setting is actually a good way of checking the radiator fan is working correctly, as this will almost always kick it on.
To maximise engine life, when starting from cold, leave it off until the engine has reached operating temperature.
