How to take factory radio out of Brava
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
E
Erik
Does anyone know how to take factory radio out of Brava in order to fit a new standart radio.
How does one disasseble the dashboard ??
Factory Radio
All you need to do is fit two feeler gauges at the sides of the stereo. At the side of the stereo there are two clips they are around half an inch from the top and bottom respectively. The top clip must be moved downwards and the bottom upwards. Just slide the feeler gauges to do this. Do one side at a time and pull it out by placing your hand in the cassette slot to pull. Do it all very gently and careful not to scratch the sides. It worked out well for me - I had to remove it to stick in the cd changer cable - good luck!
6K
David Slaney
P
15
12K
Dark Lurker
J
800
jason
J
I
694
IMC63
I
