- Joined
- Mar 25, 2018
- Messages
- 230
- Points
- 129
Unfortunately there's no other way of doing the job properly.Im really not looking forward to removing the arch liners they are a right pita.
I know this won't help you, but will help others...
Regularly during the winter, and especially at the end after the last road salt's been washed off the roads by rain, have a really good blast around the wheel arches with a hose nozzle, including the lip nearest you above the wheel (don't need a pressure washer for this). This will dislodge salt-laden mud and prevent it from holding water against the metal during after it rains. That particular area of the rear arch lining is open at the base, so you can point the hose jet up in there too from underneath . Do the same around the spring cups and rear suspension beam, and around under the front arches, especially the springs . Also the little ledge between the front wheel arch and under bonnet where a frightening amount off mud collects. Finally, open the bonnet and aim the jet into the area beyond the bonnet hinges and down toward the part of the wing that meets the front doors. Watch and you'll see mud, leaves and other crud flow out from the join between the wing and the sill. All that may when damp is the perfect breeding group for the Tin Worm.
All I have is just a really good 9 litre garden pressure sprayer which I fill with snow foam & away I go, enough to go around the car 2-3 times & a couple of times up in the front & rear arches including lips & also in that little ledge which I have to say since I put Dynax S50 in there 2 years ago is still holding up really well as hardly any mud gets in there & every time I clean the car I always make sure it's not clogged with anything & water flowing out freely. The rear beam seems to holding up good now since I covered it in Vactan in the summer, still looks like new even after winter & a good pressure wash underneath to get the winter crud off, not that there ever is a lot as the entire underneath & arches have been Bilt Hamber'ed, didn't go to mental with the Bilt Hamber around the rear arches just at the bottom where the crap collects which is now a thing of the past since applying the wax, it sheets water off like madI know this won't help you, but will help others...
