how to set the clock in fiat brava ???
Mk1 or Mk2?
Mark.
Council estate lad.
And proud of it!
Member of the Guild of Experienced Motorists.
Where's the clock??
Pretty sure I don't have one??
SEX...I'm just two women short of a Threesome
i have no manual :) and the clock is in the radio but as far as i know it is in the other chapter in the manual
"Where's the clock??"
It's the green bit at the bottom:
Also the radio frequency display and, in RDS mode, the radio station name display - amongst other things.
Mark.
Council estate lad.
And proud of it!
Ref: Clock set.
Hi there!
It depends what model radio you've got fitted.
AD182L (no cd function)
Press and hold the key with the clock symbol under it until the colon between the hours and minutes starts flashing. M1 or M2 should show on the screen.
Use the station select buttons to change the hours/minutes.
Key 2....decreases the hours
Key 3....increases the hours
Key 4....decreases the minutes
Key 5....increases the minutes.
When set, press the clock symbol key to exit.
AD182H (with cd function)
As above but use keys 1,2,3 and 4.
Key 5 changes the Mode from 1 to 2. This displays either the radio staion or the clock depending on which mode you are.
You can also set the radio to switch on/off manually or with the ignition.
With the radio off, press and hold the mute button until either 'ignition on' or 'ignition off' is displayed. Press mute to exit.
Hope this helps, remember the functions depend on which model you have.
but where is the button with the clock ikon under it??
i cant find it and that is the problem, i could figure this out if i knew that,
i have a radio without the cd
I did it!
Ok the problem is gone now!
There was no clock button etc but what you have to do is press EXP button while the radio is on than usinng buttons up and down go to the clock and set it with buttons H+, H-, M+, M-.
Thanks a lot guys but i did it myself :)
Thanks Alex you were really helpfull.
Well at least we now know you have a Mk2 radio. :)
Mark.
Council estate lad.
And proud of it!
Ahhh, I don't have a clock then, got rid of the crappy FIAT radio within a couple of weeks of buying the car!
J
956
jason
J
7K
David Slaney
P
15
12K
Dark Lurker
