Ref: Clock set.
Hi there!
It depends what model radio you've got fitted.
AD182L (no cd function)
Press and hold the key with the clock symbol under it until the colon between the hours and minutes starts flashing. M1 or M2 should show on the screen.
Use the station select buttons to change the hours/minutes.
Key 2....decreases the hours
Key 3....increases the hours
Key 4....decreases the minutes
Key 5....increases the minutes.
When set, press the clock symbol key to exit.
AD182H (with cd function)
As above but use keys 1,2,3 and 4.
Key 5 changes the Mode from 1 to 2. This displays either the radio staion or the clock depending on which mode you are.
You can also set the radio to switch on/off manually or with the ignition.
With the radio off, press and hold the mute button until either 'ignition on' or 'ignition off' is displayed. Press mute to exit.
Hope this helps, remember the functions depend on which model you have.
