Technical  How to remove side wing
Chamitri
My UNO 1.0 ie had hit on a wall and crashed the side wing. I need to remove the side wing to bring back it to original condition. But little problem. Once the front door opened there are two screws to remove. That fairly easy. One screw is located in between them and it seems for approaching to that the dash board needs to remove. Is that so? Any one could help me on this my friends.
Don't know I have named it properly? The side wing means the body part located in between the front door and head light. One signal front side light is mounted on it?
Is been a long time since i worked on a uno but i very much doubt that you have to take the dash out...
One bolt is at the bottom were the sill is, open the bonnet and you should see 2 or 3 more bolts on top of the wing, remove the side indicator and see if there is another there and i think another bolt is located behind bumper and you problably have to loosen up the bumper itself to gain acces to it...hope this helps
Thanks Alex,Turbo_pib with your guides I was able to complete the job. As you said I had to pull the carpet halfway out. Normally I am reluctant to change or remove extra things as it will demolish the original look.
Here in FIAT things are not so much easy no?
thanks again guys
