stevesteve
- Joined
- Jul 23, 2007
- Messages
- 30
- Points
- 13
Hi Everyone,
I need to repair the boss in which the rubber stop sits as my MOT flagged it as corroded and therefore failed the car. The subframe itself is sound so I can repair the boss... but I can't get the darned thing apart!
Here is the outside view:
The only bolt visible is the long one that holds the swing arm. This seems pretty solid. It has been wire brushed and given lashings of WD40 for the night.
The inside view is more knarly (apologies for the phone photos):
The bolt holding the shock came out with no dramas.
The nut on the anti-roll bar is completely solid. My socket split rather than shifting. I have given it plenty of WD40 for the night but I am going to struggle (it is already rounding slightly). Would an impact driver help here?
Similarly the nut on the long bolt acting as the hinge pin for the swing arm seems pretty solid. Again plenty of WD40 overnight.
Any ideas about how to get this lot stripped down gratefully received.
Cheers,
Steve
Cheers,
Steve
