Suz16th
- Joined
- Sep 5, 2007
- Messages
- 33
Well bloke has just called me from the garage after the service.
He said that the rear brakes are done in, pads completely worn, and are only giving 30% braking, The reak brake drums is cracked and leaking also = £310 . the front giving only 70% braking - should be 9mil are only 6mil. = £ £150
He reckons the steering is fine and swapped around the tyres. Front driver side was worn. He reckoned that this happens if one is older than the other. The kwit fit reciept I have from the previous owner show that they were both put on at the same time, but they could have been swapped around since then.
The clutch is on the way out - £290 for a new one
So £750 for the repairs??? I have no idea, but I know Mr Cluch is only charging £175 for a new clutch. What think you?
Suz
Suz
