Technical  High temp
Technical  High temp
Kevin goss
Hi.... Car been sat for the weekend went to start today came up with high temp on display and would not start... It's had a new temperature senor new battery... Any ideas what to do next??
Kevin, how old is your battery?
I have same problem 9 months replaced with new battery and all is good now.
Hi I put a new battery on now seems to be okay but now the airbag light as come on now ��
Hi I put a new battery on now seems to be okay but now the airbag light as come on now ?
Hi, on prolonged uphill climbs in a hot summer day with ac on , the temperature rises. If I stop with the engine on in 10 seconds, it reaches normal levels. It has 350,000 km. It pulls normally. I changed the water pump, radiator, thermostat. The fan works normally. The indicator goes up to the middle and something. It does not reach 3/4. Is this normal? Will I have a problem? What else should I do? I use paraflu petronas up ready -40 /125 celcius. Is it ok?
Sorry for my english
Diesel 66kw, 2006
Must be the waterways in the block are partially clogged up:unsure:, slowing the flow through it :unsure:
