General  High Pressure Pump removal
talento460
Midlands
Hi, I,m having the usual leak at the base of the high pressure pump, and it needs to come out.
Despite all the forum and web searching, I am unable to find any details on the best procedure for this.
Can some kind soul point me in the correct direction.
Thankyou
SEcond hand high pressure pump fitted, while my original is getting new seals fitted.
Going well after a 70 mile runaround today. Total time to fit pump, about 1 hour, and no timing belt or camshaft interference:)
Ironically, my HP pump has now begun leaking too lol.
I found a seal kit on ebay to suit my pump. Going to have a go at fitting it myself.
Link
Hi all. Just to update, it may be just bad luck or stupidity on my part, but I've had serious problems getting my pump to seal correctly since fitting the new seal kit (not the kit from ebay linked above, I bought locally from a diesel specialist).
High pressure side seems ok, the engine starts and runs without high pressure fuel spraying everywhere. The problem is apparent with the engine off and ignition on - while the electric feed pump runs, fuel leaks out from the 'head caps', so the leak appears to be only on the low pressure side.
My research online suggests the tightening sequence and torque for the pump heads is extremely important. Tighten evenly to 11 lbft, leave it to settle for 10 mins, then proceed to torque evenly to 18 lbft. But even adhering strictly to this method, and after multiple attempts over the weekend, my pump still leaks. The bolts themselves are actually rated for a bit more torque than this, but I'm just not willing to risk it without reliable documentation.
I've since booked in with the same specialist I bought the kit from. He's offering to rebuild the pump himself and do a pressure test for me. £60 +VAT was the estimate given on the phone, so really not bad at all if that's to be the final figure. TBH if I'd thought it could be that cheap initially, I'd have probably just gone with that. £72 is nothing compared to the stress and hassle I've had trying to do this myself while maintaining absolute cleanliness. (Not to mention hair loss when it didn't work for the fourth time around lol)
While these Bosch pumps are mechanically very simple, tolerances are minute. And as varesecrazy rightly says, any contaminants introduced during the overhaul precess have the potential to destroy the pump, and very likely the injectors too.
As a late addition I removed the fuel pump from the 1.9JTD yesterday.
Not that hard but did have it's complications. 3 x 13mm nuts hold the pump on. One easy to get at, second one lower down and on the bulkhead side of pump, needed extension bar on the 3/8 socket to undo the nut. Third one, again lower down but on the engine block side, the hardest of the lot. Very hard to see and that was the the fuel regulator plastic tank thing and EGR already removed. Not sure if patients would have prevailed at getting on this third nut but after trying for half a hour, I decided to remove the fuel rail to give me more room. Not to hard, 3 nuts and cracking off the fuel pipes. That made the difference and got at the third fuel pump nut OK. It then become apparent that the cam belt sprocket had to be undone. So it does mean the cam belt as to be interferred with. 22mm nut undone but then couldn't get the sprocket cog off. Puller might have done the trick but I got an extension bar on the threaded shaft (what the 22mm nut screws onto) and a gentle tap with a hammer and that released the fuel pump.
Bear in mind that I'm dismantling what I can before the what remains goes off to the scrapper, I don't have worry having to do the rebuild.
Now to find the ECU in case the fuel pump is coded to it.
