Technical High beam issue unresolved
shella
Essex
Hi all,
Newbie to forum. Wondered if anyone could help me with my punto grande.
Got to have re-mot by next week.
So have problem with high beam.
Side lights work and I can flash my high beam.
When I put on my headlights and flash there is no high beam, and also pull back on stalk to activate the high beam i have no high beam.
I have managed to sort all other small issues as per mot, but am left with this problem. Have checked fuses, but without a manual. Online search's brought up some to check, can't find relay for high beam if there is one.
Thank you in advance if you maybe able to help. 😀
koalar
Distinguished member
Cheshire
Will have a look on the circuit diagram later
Assuming the bulbs are okay. If one goes it fairly common for the other to fail
But if both headlights have no power
maxifuse F2
And
relay relay T3
Would be a good start
Unlikely but there are some more fuses that deal with the lights individually
F10 (left)
F11 (right).
F14 for the left headlamp and
F15 for the right
koalar
Cheshire
If I read your first post correct
If the light are from lowest highest
Side lights
Dipped
High
Side light always work
Dipped work fine
But high only work when dipped are off
Is this correct
OP
OP
S
shella
Essex
Side lights
Dipped
High
Dipped work fine
Is this correct
Yes this is correct.
OP
OP
S
shella
Essex
Side lights working fine.
Side lights
Showing (blue high beam internal light indicator on and flashing) when i go to flash on sidelights,..and all working showing on exterior bulbs.
Sidelights
Showing (blue high beam internal light indicator on) when i pull back stalk,.. for high beam selected ON. All working bulbs externally.
Dipped
Showing (blue high beam internal light indicator on) when try flash or try to pull back stalk, to select high beam on dipped.
No flash high beam/No selected high beam showing on exterior bulbs
Will check what fuses and relays you have mentioned in the morning. Thank you
koalar
Cheshire
All bulbs fuses and relays to here must be fine
Side lights
All bulbs fuses and relays work, plus the body computer to stalk is fine
Sidelights
Same as above for the stalk the other way
Dipped
Still getting the signal from the stalk so stalk to body computer is fine
Almost a waste of time. They certainly aren’t blown but may be corroded
Here’s my thoughts
I couldn’t find anyone with the exact same problem.
There are a lot of lights problems due to water getting into the fuse box. Even though I don’t think its your problem for the sake of a 5 minute visual inspection I would do this first.
A very common fault is the stalk. But as the blue light is coming on correctly I would assume this is not the case for you
The cable, fuse, relays, bulbs all work independently. There’s a good chance they are all okay
I need to check maybe they all use the same earth point and it can’t cope with the extra amps from all 6 bulbs
koalar
Cheshire
All six bulbs earth through this point
I would unbolt this clean with sandpaper, smear with Vaseline and bolt back down
bassforce007
Longridge
Have you had the vehicle plugged in to a diagnostic machine? Will possibly tell you where the problem is. Tells you when there are short circuits in the system too.
OP
OP
S
shella
Essex
So what was it, the stalk? :)
No not the stalk, loose earth wire to lights, with damp. And also today found damp in fuse box. All taken off re earthed, contact spray etc, cleaned up fuse box, put on the rad for a few hours to dry out. Hairdryer to the connections, plus contact spray. Hey press! 😂 I have all lights. Did clean up stalk connector as well, the one for the lights as this was dirty.
I managed after watching a YouTube video to revolve the end of the stalk giving me access to this.
Thank you
