Technical  Hex key size
12mm hex key for both manual transmission drain and engine oil drain.
But, before removing the drain plug to drain the gear oil, it's always a good
idea to first make sure you can actually remove the filler/level plug...
Man. trans. filler/level plug needs a 17mm wrench and is a steel plug situated
on the right hand side of the trans. casing just above the exhaust pipe - there's
not a lot of space to access the filler plug - I'd suggest you shield the exhaust
pipe with some plastic sheet or similar to make any clean-up needed, easier.
