Technical  Help!!!!
Technical  Help!!!!
BAZZA1967
Hi all
hope someone can help , my 54 plate ulysse is only firing on 3 once it has warmed up . When starting from cold it is fine .also the monocrhome display has gone, from what i can make out it states ?????????????????antipolution
thanks in advance
I doubt it is firing on 3 cylinders, probably just enters limp mode when warmed up.
Possibilities include ignition - leads - coil/s. I'd think an injection fault is unlikely, but it just might be the engine temperature sender.
SORTED
TURNED OUT TO BE AN INJECTOR , NEW ONE FITTED , RUNNING GREAT
