This problem arose on monday morning, as I was rushing out the house to work. I get in the car, turn the key and I get a start motor noise and the car trying to fire, but how ever many times I try, it will not fire. The car will turn over but will just not fire into life. So im on the third day now and these are the things ive checked:
- battery ( 2 months old and i have checked it and even put a booster pack on )
- All the fuses in the box next to the battery
- took the spark plugs out and used a light wire bush to clean them up ( was serviced 2000 miles ago)
-When I turn the key i can hear the fuel pump so i gather thats okay
-tested the coil packs ( they seem fine)
-ran a code reader on the ECU and the only error i got was brake switch failure ( my brake lights work fine) i cleared the error and it hasnt come back.
-disconnected the battery for an hour, to reset the ecu,
-also took the crank shaft sensor off and checked all the wiring and the condition of the sensor, all seems fine
I just do not know what to do now. All i can think of is that maybe there a kill switch that may of gone faulty ( type of switch that cuts the engine out if the cars in a crash) but i cant seem to find one on the stilo.....?
if anyone has any ideas, it would be great as I'm loosing my rag with the car now
