mikeknight
- Joined
- Mar 9, 2020
- Messages
- 3
- Points
- 1
Hi guys,
After some help if you don't mind??
I have a 61 reg Punto Evo dualogic. When pulling off the car shakes badly until you get going and seems to do the same at every gear change. I thought initially the clutch so we changed the clutch and its still there, we also changed the clutch fork at the same time. i also have replaced the following parts as a process of elimination, gearbox, diff, robot (complete unit), drive shafts, Throttle pedal, throttle body and gearbox mounts There were fault codes in the car that have now gone however the fault is still there the codes were...
P1770 No accelerator pedal information, present.
P1819 Engine torque (from CAN) present
P0856 VDC messages (from CAN) intermittent
P0710 Temperature (from CAN) present
Any help is very much appreciated
